B_Greene
Jan 12, 2017Aspirant
R8000 Losses Connection
Most every day when I go to use my desktop with windows 10, I have loss connection to my router. My router is an X6 R8000 and I have loaded the latest firmware through the Net Genie. If I disconnect ...
- Jan 23, 2017
Hi iamjosh,
Reset the router to factory default and manually reconfigure.
JamesGL
Mar 01, 2017NETGEAR Employee Retired
Hi All,
Try this firmware and reset. Check and observe.
http://kb.netgear.com/000037342/R8000-Firmware-Version-1-0-3-36?cid=wmt_netgear_organic
crystalgipsy
Mar 02, 2017Aspirant
When you say reset, do you mean perform a factory reset or simpy a reboot of the router?
- JamesGLMar 02, 2017NETGEAR Employee Retired
Hi crystalgipsy,
Perform a factory reset.
- JamesGLMar 06, 2017NETGEAR Employee Retired
Hi crystalgipsy,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- crystalgipsyMar 07, 2017Aspirant
Touch wood all seems good so far. Will keep you posted if have any issues.
