esk114
Nov 26, 2021Aspirant
R8000, MB8611 and Xfinity
I have an older AC3200 (circa 2017) but its been working great. Recently, I upgraded modems to a Mot MB8611 to take advantage of the 1-gig speeds. Was having problems and finally resolved the modem...
esk114
Nov 28, 2021Aspirant
Yes, I did do a reset. The lights flickered, I had to re-setup my id/password, network names changed. However, not all settings were erased. Many entries still existed.
So far, no change. Low-speeds (400-500) out of the router while the modem is now delivering the high-speed (930-960).
Nov 28, 2021Guru - Experienced User
If you pressed the reset button for 10 seconds then release or use the ERASE funciton on the routers web page under Admin/Backup? ERASE should and will erase all prior configurations.
Something to try if you can to see if your router is working right on the WAN to LAN speed side of things:
https://www.duckware.com/tech/router-wan-to-lan-throughput-test.html
Seems like HW nat accelleration isn't working on your router maybe...
