Bobby121418
Nov 28, 2021Aspirant
R8000 NAT/port forwarding issue
Hi, I just got the R8000 and it sits between my service provider modem/router and my Synology NAS. I have configured the R8000 to be on a different subnet (192.168.1.1) to my broadband provider (EE ...
Nov 28, 2021Guru - Experienced User
This would be a double NAT condition which isn't recommended.
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setup
Try option #1 first, if not, #2...
- Bobby121418Nov 29, 2021AspirantHi,
Thank you very much for your suggestions. I have in fact configured as option 2 as you suggested because the modem/router does not allow bridge mode. I am still however having the issue I mentioned.
Thanks- FURRYe38Nov 29, 2021Guru - Experienced User
Depending upon now well the DMZ or IP pass thru is on the ISP Modem, you may still encounter the double NAT issue.
You may need to put the R8000 in to AP mode and let the ISP modem handle the NAT.
Hi,
Thanks for your help so far.
So I have done a tracert (via CMD) and its funny because I can get route traces for sites, such as the BBC or CNN, but cannot get my NAS domain name address resolved. It's as if DNS is not recognising my domain name. However, if I try to access my domain name from outside my LAN, I can get through.
Any thoughts? Is it a certificate problem ever since I added the Netgear router in?
Thanks
