Bobby121418
Nov 28, 2021Aspirant
R8000 NAT/port forwarding issue
Hi, I just got the R8000 and it sits between my service provider modem/router and my Synology NAS. I have configured the R8000 to be on a different subnet (192.168.1.1) to my broadband provider (EE ...
Bobby121418
Nov 29, 2021Aspirant
Hi,
Thank you very much for your suggestions. I have in fact configured as option 2 as you suggested because the modem/router does not allow bridge mode. I am still however having the issue I mentioned.
Thanks
Thanks
Nov 29, 2021Guru - Experienced User
Depending upon now well the DMZ or IP pass thru is on the ISP Modem, you may still encounter the double NAT issue.
You may need to put the R8000 in to AP mode and let the ISP modem handle the NAT.
- Bobby121418Nov 29, 2021Aspirant
Hi,
Thanks for your help so far.
So I have done a tracert (via CMD) and its funny because I can get route traces for sites, such as the BBC or CNN, but cannot get my NAS domain name address resolved. It's as if DNS is not recognising my domain name. However, if I try to access my domain name from outside my LAN, I can get through.
Any thoughts? Is it a certificate problem ever since I added the Netgear router in?
Thanks
- FURRYe38Nov 29, 2021Guru - Experienced User
If your trying to get responced back thru the router, not sure if this model supports loop back which is sometimes needed when resolving from the LAN to WAN back to LAN side.
If the R series router is in the ISP modems DMZ, this should help alleviate some of the double NAT issues however I've see some ISP modems not do DMZ or IP passthru correctly.
You might try the NAS connected to the ISP modem and see if it works there with out the R series router online...
- Bobby121418Dec 06, 2021AspirantHi,
Thanks for your suggestions.
So, I had the configuration initially where my NAS was connected directly to the ISP router and all was fine.
I tried your solution by putting my ISP router in DMZ mode to the NG R router. The problem is twofold:
1. The NAS now connected to NG R however, I can only connect to the NAS via 192.xxx.xxx.xxx IP while at home (on WiFi) and the DDMS domain does not work. The domain address only works if I am on an external network i.e on mobile.
2. I get video streamed from the NAS onto TV on the same Lan with a lot more buffering than when the NAS was connected directly to the ISP router and no NG router in the middle.
Thanks
PS. My ISP router doesn't do bridge so the option as you suggested was DMZ and no firewall or DHCP.
