HH2
Apr 28, 2023Aspirant
R8000 NH router still dropping all Wi-Fi connections
My NG NH 8000 router - I have manually updated the FW & factory reset this router & it still keeps dropping ALL wifi connections to my home devices, even devices located next to my R8000 NH router. It...
Apr 28, 2023Guru - Experienced User
How long have you had the router?
Do the WiFI LEDs change color at all when this happens?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many
Try going back to last working FW version?
Be sure for Apple and Android devices, disable any MAC ADDRESS randomizer features while at home:
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Possible that the router is failing and needs to be replaced. v.84 is current and would not be a FW issue. Others haven't reported this and I didn't see this with my R8000 when I had it online last year.
One option you could do is disable the wifi radios, and use the wired portion of the router. Install a 2ndary external WiFi AP and use this for the wifi system with the router portion of the R8000. Just if you wanted to keep the R8000 going.
HH2
Thx for your reply. I work in IT (cisco) & I have jumped through those hoops you suggested. This thing is trash!!! I’m going to go Office Space on it & NEVER BUY ANOTHER NETGEAR PRODUCT AGAIN!….Anyway, thx again & have a great weekend!
- FURRYe38Apr 28, 2023Guru - Experienced User
Good Luck.
- HH2Apr 28, 2023AspirantGood luck? With what exactly? No luck involved to purchase a router, unlike yours, that functions properly…Thx again, for nothing.
- plemansApr 28, 2023Guru - Experienced User
Did it just start having this issue?
How long has it been going on for?
Is it issues with both the 2.4ghz, one of the 5ghz, or all 3 radios?
Do wired devices have issues?
