vdotmatrix
Sep 27, 2022Guide
R8000 nighthawk Config issue lack of service
I’ve had this issue with this router for over a year. I was finally able to get a hold of Netgear customer support and after troubleshooting a number of issues out of warranty the guy try to sell me ...
vdotmatrix
Sep 27, 2022Guide
Hi I think we’ve talked many many times in the past having the same issues. Connectivity issues. You suggested that I downgrade the firmware. I might as well try to re-task some high-level satellites orbiting over Bosnia.
vdotmatrix
Sep 27, 2022Guide
I do not know how do downgrade the firmware. Is it easy to do? I have the nighthawk app installed on the phone and ipad…
thanks
- FURRYe38Sep 27, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a factory reset and setup from scratch been performed since last FW update?
- michaelkenwardSep 28, 2022Guru - Experienced User
Pretty easy. It is the same process as a manual update of the firmware.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
I have the nighthawk app installed on the phone and ipad…I don't think that you can use that for anything beyond basic housekeeping in a router.
Manual updates are usually done with a wired LAN connection using the browser graphical user interface (GUI).
