vdotmatrix
Nov 08, 2021Guide
R8000 nighthawk ethernet issue
i have an SB6183 modem and the R8000 nighthawk router and an 8-port switch. this has been the house system config for at least a decade. Modem>ethernet cable>R8000>Ethernet cable>8-port ethernet swi...
- Nov 13, 2021
After a painful interval of research, the saga is finally over.
I installed a new gs116NA switch, and only used one ethernet port on the R8000 to supply it and EVERYTHING works now.
A bad 8-port ethernet switch was the cause of so much grief.
vdotmatrix
Nov 09, 2021Guide
It is just bizarre that all of a sudden the ethernet partially only works thru the router.
All ethernet stations in the house are home run from every room to the central location and either to the 8-port ethernet switch or the 4-ports on the router (one used to supply the switch).
i was hoping to pin point the issue and just say it was the old 8-port switch....but i have nothing definitive but will continue to play with it; i have a new unopened 16-port switch ready to deploy.
I really appreciate your help, cuz otherwise i would have no direction with this troubleshooting.
vdotmatrix
Nov 13, 2021Guide
- vdotmatrixJul 04, 2022Guide
We’re back!
Intermittent internet connectivity.
When it works, it works.
Is there a way to send the wireless router somewhere to have it tested?
this is the most expensive Wireless device ever .
is there a self test or something else i can do to troubleshoot?
- plemansJul 04, 2022Guru - Experienced User
have you tried downgrading the firmware?
- vdotmatrixJul 05, 2022Guide
Down grading?
- plemansJul 05, 2022Guru - Experienced User
yes, the firmware.
Sorry, thankyou, hate to tie up this thread but is there a known issue with the current firmware? What are symptoms of problems with this update?
- plemansJul 06, 2022Guru - Experienced User
Its more an issue of "some devices have issues" versus all devices have issues. Which is why we recommend trying downgrading a version or 2 for those that do have issues.
- vdotmatrixJul 22, 2022Guide
Is there anyplace i can take this to have checked out?
