vdotmatrix
Nov 08, 2021Guide
R8000 nighthawk ethernet issue
i have an SB6183 modem and the R8000 nighthawk router and an 8-port switch. this has been the house system config for at least a decade. Modem>ethernet cable>R8000>Ethernet cable>8-port ethernet swi...
- Nov 13, 2021
After a painful interval of research, the saga is finally over.
I installed a new gs116NA switch, and only used one ethernet port on the R8000 to supply it and EVERYTHING works now.
A bad 8-port ethernet switch was the cause of so much grief.
Jul 06, 2022Guru - Experienced User
Its more an issue of "some devices have issues" versus all devices have issues. Which is why we recommend trying downgrading a version or 2 for those that do have issues.
vdotmatrix
Jul 22, 2022Guide
Is there anyplace i can take this to have checked out?
