gwenjusty44
Nov 10, 2021Tutor
R8000 Nighthawk Router
Will the Nighthawk Tri-Band WiFi 6 Mesh Add-on Satellite work with my R8000 router?
Nov 10, 2021Guru - Experienced User
What one? you didn't put the model number.
Thanks a bit of key.
- gwenjusty44Nov 11, 2021Tutor
The router is the Nighthawk X6 AC3200 Smart WiFi router.
- plemansNov 11, 2021Guru - Experienced User
Not router. What satellite/extender are you trying to add?
I'd like to add a mesh device to our current router. I have an extender, but it's a pain to work with,
