Dheeraj1
Nov 29, 2020Aspirant
R8000 Nighthawk X6 AC3200 kicks off all devices every few hours
Hi all, For the past few months, my router has periodically (every few hours) been kicking out all the devices connected to it. While some devices, especially phones, connect back almost instantl...
Nov 30, 2020Guru - Experienced User
I haven't been a fan of the firmware on the R8000 since they added in netgear armor.
I'd recommend dropping back to version 1.0.4.28 of the firmware. After downgrading, factory reset the router and do a clean install (not from a backup). Disable auto-updates after that.
See how it performs like that.
- Dheeraj1Dec 03, 2020AspirantI tried downgrading the firmware version but it didn't fix the problem. In fact, it seems the problem was made worse as more devices are taking longer to reconnect.
- plemansDec 03, 2020Guru - Experienced User
what modem/gateway do you have?
Did you do a reset and clean install after downgrading?
I have a Virgin Media Hub 3 as my modem.
After the downgrade, I factory reset the router using the hole at the back of the router. Is that what you mean by clean install?
