DSS1947
Jul 30, 2016Tutor
R8000 Nighthawk X6 AC3200 only gets half internet speed
My ISP bumped my internet speed from 26mbps to 50mbps. My cable modem is hardwired to my computer. When I run tests I still get 26mbps. I called my ISP and they had me bypass the router at which time...
- Aug 08, 2016
Thanks for the advice guys. I did finally get a chance to reset the router to default and it solved the problem.
Retired_Member
Jul 31, 2016Try using default settings, press reset until power Led flashes....the speed using a wired connection to lan port should be close to a direct modem connection speed
Mikey94025
Jul 31, 2016Hero
As searay said, go back to default settings and see if you still lose the speed. There are some features that you cannot enable without also limiting your network speed thru the router (e.g., QOS, traffic filtering, port forwarding/triggering). You can search the community posts for "CTF speed" and find other topics that discuss router speed loss.
- DSS1947Aug 08, 2016Tutor
