DSS1947's avatar
DSS1947
Tutor
Jul 30, 2016
R8000 Nighthawk X6 AC3200 only gets half internet speed
My ISP bumped my internet speed from 26mbps to 50mbps. My cable modem is hardwired to my computer. When I run tests I still get 26mbps. I called my ISP and they had me bypass the router at which time...
  • DSS1947's avatar
    DSS1947
    Aug 08, 2016
    Thanks for the advice guys. I did finally get a chance to reset the router to default and it solved the problem.
