MongooZ
Oct 06, 2016Aspirant
R8000 Nighthawk X6 AC3200 only gets half internet speed
Hello guys, So here i come with my weird issue. My router simply drops half bandwith (download only) after 24 hours. Let me explain. My ips bumped my bandwith to 200mbps/30mbps from 100/20. After...
- Retired_MemberOct 06, 2016
replace the cable between modem and router WAN port SHOULD connect @ 1000m
make no mistake WMM needs to be enabled For WIFI
Retired_Member
Oct 06, 2016replace the cable between modem and router WAN port SHOULD connect @ 1000m
MongooZ
Hello searay !
Thank you for your suggestion ! Before buying a new cable, which i will tomorrow, may i ask why you think this should fix my problem?
thank you
the wan port must connect @ 1000m your previous post shows it at 100m either bad modem, bad cable, bad router or bad firmware but you already changed FW
- MongooZOct 06, 2016Aspirant
Correct ! Then i'll grab new set of cables tomorrow and give it a try; i'll keep you updated.
Thank you very much searay
