MongooZ
Oct 06, 2016Aspirant
R8000 Nighthawk X6 AC3200 only gets half internet speed
Hello guys, So here i come with my weird issue. My router simply drops half bandwith (download only) after 24 hours. Let me explain. My ips bumped my bandwith to 200mbps/30mbps from 100/20. After...
- Retired_MemberOct 06, 2016
replace the cable between modem and router WAN port SHOULD connect @ 1000m
make no mistake WMM needs to be enabled For WIFI
Retired_Member
Oct 06, 2016replace the cable between modem and router WAN port SHOULD connect @ 1000m
MongooZ
Oct 09, 2016Aspirant
Thank you very much searay, problem fixed by replacing cable from modem to router !
- Retired_MemberOct 09, 2016
Great News!
You're welcome
