AlanD96
Nov 11, 2016Tutor
R8000 Nighthawk X6 AC3200 only gets half internet speed
I was set up with Comcast Gigabit service earlier this week and all was fine, a solid 950 Mpbs. speed using Ethernet. Then suddenly the next day, my speed dropped to about 400Mpbs. I thought the p...
- Nov 16, 2016
No one answered my question but I figured out the answer to the problem myself and thought it would be helpful to someone receiving this router for gigabit speeds.
I discovered by trial and error that when I ENABLED the traffic meter, which is OFF by default, THAT is when my speed dropped from 940 Mpbs. down to 400 or so. As soon as I turned it off, my speed went back to normal.
Who'd have thought?
AlanD96
Nov 16, 2016Tutor
Who'd have thought?
Retired_Member
Nov 16, 2016I was trying to find the actual answer when you posted
At higher speeds the CPU cannot support options and high speeds so it slows the speed of the router. There are other post on this but I can't remember the exact answer.
