MarkusF
Feb 25, 2022Follower
R8000 Nighthawk X6 AC3200 Tri Band WiFi Gigabit Route-will it work with Nighthawk X6 Mesh Extender?
Hi I purchased this router 2016 and am now wondering if this router is able to work/connect with the Nighthawk X6 Tri-Band WiFi Mesh Extender, thanks for answers?
Please review the quick install guides and user manual for the EX extender to get it setup.
https://www.netgear.com/support/product/EX8000.aspx
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender (EA and EAX Series) products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you. - plemansGuru - Experienced User
You d idn't actually put what extender you're wanting but all of netgears extenders work with their routers.
