bearsfan9
Apr 15, 2022Follower
R8000 NightHawk X6 AC3200 Tri-Band WiFi Router
I have an R8000 NightHawk X6 AC3200 Tri-Band router. I have two older Netgear DST units in certain areas of my house for additional signal strength and range. Can these work with my R8000 router? I d...
Apr 15, 2022Guru - Experienced User
What is "Netgear DST"?
- fredvon4Apr 17, 2022AspirantWhat is DST in router?The DST Adapter (DST stands for "Dead Spot Terminator") is a HomePlug AV2-connected simultaneous dual-band 802.11ac access point. The DST does not function as a wireless-connected extender.
- FURRYe38Apr 17, 2022Guru - Experienced User
Something that you can try and see if they work.
