Wiifii2
Nov 02, 2023Aspirant
R8000 Nighthawk X6 won't turn on
I had some problems with my router, mainly that the Internet was kicking out. This happens frustratingly every so often. About an hour later, I notice it hasn't come back on like it usually does. I tu...
Nov 02, 2023Guru - Experienced User
Try a different power supply with same volts and amps. If it still fails, router needs to be replaced.
- Wiifii2Nov 02, 2023AspirantIt's routed through an Xfinity product of some kind, so I don't know where the power source is
- FURRYe38Nov 02, 2023Guru - Experienced User
There is a power adapter brick that plugs into the wall out let for the power.
- plemansNov 03, 2023Guru - Experienced User
Wiifii2 wrote:
It's routed through an Xfinity product of some kind, so I don't know where the power source isIt shouldn't be far. The power cord is only like 6ft. Should be pretty easy to trace back to the outlet
- michaelkenwardNov 03, 2023Guru - Experienced User
plemans wrote:
Look at the bit of wire that goes from the "DC" socket:
It is plugged into the mains somewhere.
You need to check that the adapter isn't bust.
You just need to find something that has the right specifications (volts and amps) are pretty standard, and that fits into the socket. If there's an old Netgear device lying around, that might do the trick.
