Ericglo
Jan 02, 2021Follower
R8000 not detected internet connection
Router worked fine for 3 months until last night. I have reset router and modem but it did not help. Called cable provider and was told wifi is the problem since cable Tv works fine Ethernet hardwired...
Jan 03, 2021Guru - Experienced User
We need more info.
1. what modem/gateway is it connected to?
2. Firwmare on the router?
3. What are the led's on the router showing? (color, blinking, etc)
4. Do wired devices have issues? Only wireless? Is it saying "connected, no internet". What actual issue is going on/happening? We aren't there to see so the more details you can give us, the better we can help.
