LBonham104's avatar
LBonham104
Follower
Mar 02, 2023
R8000 Not Receiving VPN Connection
I have the R8000 Nighthawk router and after an update, it is no longer connecting to my VPN. The router does connect to WiFi just fine. I have ran a factory restart and the VPN connection is not working. I have tired connecting to the VPN in other locations using other routers and it does work. It seems the problem might be my router. What do I need to check for?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Which VPN?
    Update what? Firmware? Which version?
    Does it mend the VPN if you reinstall the previous version?
    Start with the settings that your VPN provider suggests.
