jradke19
Apr 21, 2021Aspirant
R8000 not working, amber light on for internet
we have wired PC's running off the modem that are working fine but router has orange amber light for internet and no wifi...also cant connect with routerlogin.net...what do we do?
- wcalifasProdigy
did you try to power off and on the router to see if that fixes it?
- jradke19Aspirant
Yes powered on the modem and router multiple times, wired network still works great but no wifi still and the amber light is still on
- wcalifasProdigy
ok when you have your router powered, press on the reset button with a paper clip for 30 seconds and see if that fixes it. It will be reset back to factory settings. See if that fixes it.
