harleykins
Jun 16, 2016Aspirant
R8000 not working at all
I purchase the Nighthawk R8000 Router almost a year and a half ago. On Tuesday this week (the 14th), we started experiencing connectivity issues with the Wifi. Some of our devices were failing to co...
- Jul 06, 2016
Hi Harleykins,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
harleykins
Jun 22, 2016Aspirant
Thanks for your reply! There is no internet light. I can access the internet just fine connected to my computer. Because I'm a bit of a packrat, we're using our old router for our home and not having any issues with connectivity. I've held the reset button for a few minutes and nothing happens, no lights flash. They just stay lit to white.
JamesGL
Jun 22, 2016NETGEAR Employee Retired
Hi harleykins,
1. When connected to the router, can you still get an IP address on your computer. If yes, what is the IP address? And can you ping the default gateway?
- harleykinsJun 24, 2016Aspirant
I don't get an IP address and I can't ping the default gateway nor access it through the local network. It looks like it's not connecting to the local network at all.
- JamesGLJun 26, 2016NETGEAR Employee Retired
Hi Harleykins,
Please set a static IP and default gateway on your computer and ping the default gateway. Check if you are getting a response.
IP:192.168.1.2
DG:192.168.1.1
- JamesGLJun 29, 2016NETGEAR Employee Retired
Hi Harleykins,
- harleykinsJun 30, 2016Aspirant
Pinging results in Destination Host is Unreachable. There is no response from the router no matter what I do.
