cappy2112
Nov 30, 2020Guide
R8000 only getting half download speed on Comcast Xfinity 600Mb service
I have recently upgraded to the Xfinity 600Mb download internet service. I've got an R8000 router with V1.0.4.62_10.1.74 firmware. The cable modem is an Arris SB6190. Both are more than capable ...
Nov 30, 2020Guru - Experienced User
1. factory reset the router. Then do a clean install, not from backup. i've read of settings being retained even though a device is rebooted.
2. Leave access control, parental control, qos, and traffic monitoring all disabled.
3. The built in app doesn't always choose the best server. its a nice feature but not that useful for peak testing.
4. Wireless isn't going to max out a 600mbps connection on the R8000. Only hardwired will. Make sure to test hardwired. When using the speedtest app hardwired, try several servers in case it picks a slow server.
to get an accurate representation of expected wireless performance, take a look at smallnetbuilders review. it did a great job
NETGEAR R8000 Nighthawk X6 Review: Part 2 - SmallNetBuilder
cappy2112
Nov 30, 2020Guide
Thanks
The routers are supposed to retain their settings after they are rebooted.
These are already disabled
I've also tried testing the speed using the Speedtest client on my laptop.
I don't have anything with ethernet ports any more. The comcast tech did both router AND modem tests separately, using wired ethernet. It still points to the router being the bottleneck.
- plemansNov 30, 2020Guru - Experienced User
cappy2112 wrote:Thanks
The routers are supposed to retain their settings after they are rebooted.---sorry, it should have said "even after a service has been disabled and the router rebooted".
These are already disabled----See above, if they were enabled, cut through forwarding gets disabled with is what allow for speeds more than 250mbps.
I don't have anything with ethernet ports any more.----Then you aren't going to see the 600mbps that you pay for. The only way you're going to max them out is hardwired in. The comcast tech did both router AND modem tests separately, using wired ethernet.----and is the tech going to come out each time you want to test hardwired? Probably not. time to borrow a laptop/pc to test with. Or order a usb---ethernet adapter to test with. It still points to the router being the bottleneck.---it probably was. If you'd had those services on, it disables cut through forwarding. And sometimes it takes a factory reset to re-enable it. If you don't want to take those steps, that's on you. there's only so much we can do to help before it comes down to the end user.
