ThePie
Feb 19, 2016Aspirant
R8000 Open VPN Drops Internet Upon Connecting
I have a R8000 router and sometimes when I go to connect using the Open VPN connection it will show as connected but I won't have any internet access anymore. My connection log is below. The XXX is w...
- Mar 02, 2016
Actually I found a way around the issue. If you change the protocol from UDP to TCP everything works fine. Not sure what the issue is with UDP though.
JamesGL
Mar 02, 2016NETGEAR Employee Retired
Hi ThePie,
1. Is the main adapter still enabled and connected with valid IP address?
2. Make sure the main adapter doesn’t conflict with the OpenVPN router’s network. Ex if R8000 is 192.168.1.1, the outside LAN network should be on another subnet.
ThePie
Mar 02, 2016Aspirant
