Luke_N
Nov 15, 2023Follower
R8000 OpenVPN TLS V1.1
Hi Tech community, Firstly apologies if this has been covered before, I did try to search and though numerous posts regarding OpenVPN exist I couldn't see one for this use case. I have update...
Kitsap
Nov 15, 2023Master
Luke_N wrote:Hi Tech community,
I have updated a Windows based client to the latest OpenVPN release (2.6.7) and I am unable to connect due to TLS version mismatch, error message found in logs below:
TLS error: Unsupported protocol. This typically indicates that client and server have no common TLS version enabled. This can be caused by mismatched tls-version-min and tls-version-max options on client and server. If your OpenVPN client is between v2.3.6 and v2.3.2 try adding tls-version-min 1.0 to the client configuration to use TLS 1.0+ instead of TLS 1.0 only
OpenSSL: error:0A000102:SSL routines::unsupported protocol:
I have checked my router is running the latest firmware... am I to assume there is no current support for TLS 1.1 on R8000? So I will fall back to a earlier version of OpenVPN client for now but this is not ideal for security
Thanks in advance
Luke
How long has it been since you re-created the configuration files and updated your client devices?
So far, I am not having any issues with the OpenVPN version 2.6.7 and the client configuration files created with my R9000. The update to OpenVPN version 2.6.7 was a non event on Windows 10 client machines. I did not update the client configuration files to use with the updated version 2.6.7 application.
