MarkIndiana
Jun 08, 2017Aspirant
R8000 password does not protect
 Hello,     Curious problem. Upon changing router password on my Nighthawk R8000, my tablet can still use two of the three icons to use the network. Powered off the tablet and brought it back up and i...
- Jun 14, 2017
This is the usual way of accessing your device.
Just point your browser at one of these addresses:
http://www.routerlogin.com/
or
http://www.routerlogin.net
If they don't work, then the IP address might be an option. Here the usual suspects are:
http://192.168.0.1
or
http://192.168.1.1
Check the manual, which you can get here:
R8000 | Product | Support | NETGEAR
This explains what to do.
MarkIndiana
Okay, my tablet is a Samsung. Parent's tablet has the ability to do the same thing, their tablet is an LG. They are/were able to access the network without logging in. Is this a concern? Is the router protected? Is the network?
Thanks.
- FURRYe38Jun 08, 2017Guru - Experienced User
Did you change the PW for all wifi SSID names? Besure to try and forget or delete prior used profiles on your devices then set up the new connection again. Change the SSID name and PW on all radios to something unique between each radio so you know which one your connecting too.
Use WPA2 and AES only for best security.
- MarkIndianaJun 08, 2017Aspirant
Hmmm. No, I did not and that probably is the problem. I though quite simply that changing one changed all. I will do this immediately. Thank You!
Okay, I see where I can change the pw for Netgear65 2.4ghz...done. Additionally, I see where I can change the pw for Netgear65-5g-2 5.0ghz...done. How do I change the pw for Netgear65-5g-1 I do not see a tab for it?
Should be all on the same tab, scroll down further.
