MarkIndiana
Jun 08, 2017Aspirant
R8000 password does not protect
 Hello,     Curious problem. Upon changing router password on my Nighthawk R8000, my tablet can still use two of the three icons to use the network. Powered off the tablet and brought it back up and i...
- Jun 14, 2017
This is the usual way of accessing your device.
Just point your browser at one of these addresses:
http://www.routerlogin.com/
or
http://www.routerlogin.net
If they don't work, then the IP address might be an option. Here the usual suspects are:
http://192.168.0.1
or
http://192.168.1.1
Check the manual, which you can get here:
R8000 | Product | Support | NETGEAR
This explains what to do.
MarkIndiana
Jun 14, 2017Aspirant
Yes, I am using the genie. Web interface? Do tell....:-)
michaelkenward
Jun 14, 2017Guru - Experienced User
or
http://192.168.0.1
or
http://192.168.1.1
- MarkIndianaJun 14, 2017Aspirant
That did it Michael.
Why, for the love of Pete, does the Netgear Genie not give access to it?
I appreciate the help!
Thanks to everyone that posted.
 - michaelkenwardJun 14, 2017Guru - Experienced User
MarkIndiana wrote:Why, for the love of Pete, does the Netgear Genie not give access to it?
Excellent question.
I was under the impression that there was a way in. But when I went to look for it, it wasn't there. Perhaps this is another thing they removed in the last "improvement" to the genie.
