Duraipunk
Dec 03, 2020Tutor
R8000 Plex issues no external access
I’ve just bought the r8000 which I have plugged into a Virgin Homehub set to Modem mode. I have a Synology ds112j Nas attached via Ethernet and an Nvidia Shield running plex media server. I cannot ...
- Dec 04, 2020
The hub.
Dec 03, 2020Guru - Experienced User
What I'd try?
Putting the home hub back in router mode, disable its wifi, and the netgear in access point mode.
the home hubs aren't known to have the best function modem only/passthrough mode.
Duraipunk
Dec 04, 2020Tutor
I’ll have one last head scratching, hair pulling afternoon of port frustration and the I’ll give that a whirl.
- plemansDec 04, 2020Guru - Experienced User
good luck!
It can be frustrating when using ISP supplied devices. There's not much drive for the ISP to have them run with another router.
