wmdeac's avatar
wmdeac
R8000 preset specific password stamped on the ID plate
I purchased a used R8000 X6 router some time back. There was the usual "admin, password" detail on the bottom ID plate, but also a more elaborate password stamped in as well. Is this typical of this ...
  • plemans's avatar
    Nov 07, 2021
    the default login/password to connect through the gui is
    login: admin
    password: password
    the wireless ssid/password will be on a label. but its just a default. If it'd been changed it might be something different.
    You can try factory resetting to get back to the default ssid/password.
