wmdeac
Nov 07, 2021Aspirant
R8000 preset specific password stamped on the ID plate
I purchased a used R8000 X6 router some time back. There was the usual "admin, password" detail on the bottom ID plate, but also a more elaborate password stamped in as well. Is this typical of this ...
- Nov 07, 2021
the default login/password to connect through the gui is
login: admin
password: password
the wireless ssid/password will be on a label. but its just a default. If it'd been changed it might be something different.
You can try factory resetting to get back to the default ssid/password.
wmdeac
Are you saying other than the typical admin, password initial id? Mine had a different password stamped on the plate, "widemesaXXX".
Nov 07, 2021Guru - Experienced User
login: admin
password: password
