BuBBles827
Apr 13, 2022Aspirant
R8000 router acting weird suddenly
Suddenly the router is blocking my phone from being connected to the WiFi. When I login to routerlogin.net using my laptop and chrome, I can access the router. But if I make any changes and hit 'app...
- Apr 13, 2022
I recommend that you downgrade to v.68 or .62. There are some DNS issues for some users on recent FW. I saw this as well with .76 loaded so I reverted back to v.62. NG is aware of these issues and working on something.
Apr 13, 2022Guru - Experienced User
Be sure to clear out all browser caches before going to the routers web page.
Does this happen on other browsers?
- BuBBles827Apr 13, 2022Aspirant
Hi
Thank you for responding.
I was running the previous firmware version when all this started. Then when I logged into the router I saw there was an upgrade so I installed that today. I then double checked that the upgrade actually installed by checking for upgrades on the router.
I've been connected to the Arris TM804 modem for a few years.
I cleared the Chrome caches multiple times.
And this happens on both Chrome and Edge.
- FURRYe38Apr 13, 2022Guru - Experienced User
- BuBBles827Apr 14, 2022Aspirant
Hello
I'm not sure how to do that. Can you please post some instructions on how to downgrade.
Also what is FW?
Thanks
