N3th4wk
Mar 05, 2023Aspirant
R8000 router connected with BT FFTH
Hi, I need help in setting up my R8000 router with a BT hub after we have just had installed FFTH. The Bt engineer has connected the Fibre to one of my 4 ethernet connections on the BT hub, and enabl...
Mar 05, 2023Guru - Experienced User
Has to be the Yellow WAN port in back of the R8000.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Try the R8000 in AP mode with out IP Pass thru on the ISP router.
