N3th4wk
Mar 05, 2023Aspirant
R8000 router connected with BT FFTH
Hi, I need help in setting up my R8000 router with a BT hub after we have just had installed FFTH. The Bt engineer has connected the Fibre to one of my 4 ethernet connections on the BT hub, and enabl...
N3th4wk
HI FURRYe38, I have tried the set up as you have suggested, but I still get an orange light on theR8000 unit for internet connection, so I don't believe I have a live internet connection, the light occasionally flickers like its trying to make a connection but nothing happens
Any other suggestions would be most welcome
Mar 06, 2023Guru - Experienced User
Try the R8000 in AP mode with out IP Pass thru on the ISP router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Has a factory reset and setup from scratch been performed since last update?
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
- N3th4wkMar 09, 2023Aspirant
Hi againFURRYe38, can you please explain in simply words how I get this R8000 into AP mode, when I cant connect to it
- michaelkenwardMar 09, 2023Guru - Experienced User
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
And, of course, the manual:
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
