N3th4wk
Mar 05, 2023Aspirant
R8000 router connected with BT FFTH
Hi, I need help in setting up my R8000 router with a BT hub after we have just had installed FFTH. The Bt engineer has connected the Fibre to one of my 4 ethernet connections on the BT hub, and enabl...
N3th4wk
Mar 09, 2023Aspirant
Hi againFURRYe38, can you please explain in simply words how I get this R8000 into AP mode, when I cant connect to it
michaelkenward
Mar 09, 2023Guru - Experienced User
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
And, of course, the manual:
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
