MyBrokenRouter
Jan 26, 2022Initiate
R8000 Router Ongoing DNS Issues
So the DNS resolution issues affecting the R8000 and seeminly other models are all over this forum. The last two firmware upadates (.74 and .76) are complete junk and completely break the DNS resolut...
Kadaro
Dec 05, 2022Aspirant
Hi, thanks for the reply
I tried all the options/suggestions like disabling the IPV6.
I did noticed that some secure web pages, or regular web pages (banks and others) fail loading at first attempt.
Its better with IPV6 on, but not perfect.
I also note that Netflix fails usually the first attempt to connect from any of my Roku's or Samsung apps. If you stop and retry it works.
In both cases I wonder if they have load balancers out there that don't have all the correct DNS pointers (for either IPV6 or 4)
To confirm that idea, I did have some success fixing my host file with an DNS IP that works and it had some good results as well....but not 100%.
You would think Netgear would have solved this by now.
Dec 05, 2022Guru - Experienced User
You'd think but I also doubt they have the resources dedicated to an 8 year old router (released in 2014).
