RaymoC
Aug 18, 2017Aspirant
R8000 Slow WiFi download Speeds
Hi guys, I'm wondering if anyone can help me as I am on my second Nighthawk R8000 and I am getting nowhere near the download speeds I should be getting, any suggestions would be appreciated. I a...
- Sep 13, 2017
I am sorry an exchange did not work for you.
I did not use the "smart connect" feature - when I enabled this in the original router it seemed to slow my speeds down.
I settled on 2 seperate 5ghz wifi networks just as it comes out of the box.
Mine has been rock steady now since the exchange - I changed absolutely nothing at all out of the box - I only opened a port for a torrent file.
I am still amazed that I regularly get over 300 meg dload a floor above on a 300meg line - hardwired to the router it nudges 320 meg dload - just amazing.
The only thing I have noticed is that my NEST thermostat seems to disconnect from wifi every few days - it auto reconnects every single time so no big dramas - but I'm not too sure if it needs re-pairing to the new router or whether it's NEST servers.
Everything else connected to the router works flawlessly (around 25 different items) - Smart TV's, Nvidia Shield, Ring Doorbell, Tablets, Phones, Pc's etc.
Dave
whiteswan
Sep 05, 2017Guide
Hi
I have same set up as yourself - apart from I am on Virgin Media 300 dl / 20 up.
My original X6 was same as yours - slow speeds and disappearing wifi.
I tried everything - different firmwares - factory resets - changing values in set up - it would work for a day - maybe 2 - but then would crap out again.
Netgear seem to take 3 weeks just to answer questions on here - so I gave up and swapped it for another X6 (I purchased it from Amazon - they were happy to swap it)
The new one is flawless - I get 300 meg dl/19up a floor above the superhub3 which is in modem mode.
It's my opinion that there is a "bad batch" of routers out there - swap it and hopefully it will solve your problems.
Dave
RaymoC
Sep 06, 2017Aspirant
Thanks Dave I'll get in touch with Amazon and see if I can swap for another.
This is my second one I am on now, this one seems like it has more recent packaging as it has an European Awards 2016 on it the last one didn't.
I'm really disappointed with this router for one it's not the cheapest - I kind of just accepted that this is what I will be getting.
Thanks very much for replying and letting me know, fingers crossed Amazon can help me and I get a good one.
I'll let you know how I get on!
Raymond
