RaymoC
Aug 18, 2017Aspirant
R8000 Slow WiFi download Speeds
Hi guys, I'm wondering if anyone can help me as I am on my second Nighthawk R8000 and I am getting nowhere near the download speeds I should be getting, any suggestions would be appreciated. I a...
- Sep 13, 2017
I am sorry an exchange did not work for you.
I did not use the "smart connect" feature - when I enabled this in the original router it seemed to slow my speeds down.
I settled on 2 seperate 5ghz wifi networks just as it comes out of the box.
Mine has been rock steady now since the exchange - I changed absolutely nothing at all out of the box - I only opened a port for a torrent file.
I am still amazed that I regularly get over 300 meg dload a floor above on a 300meg line - hardwired to the router it nudges 320 meg dload - just amazing.
The only thing I have noticed is that my NEST thermostat seems to disconnect from wifi every few days - it auto reconnects every single time so no big dramas - but I'm not too sure if it needs re-pairing to the new router or whether it's NEST servers.
Everything else connected to the router works flawlessly (around 25 different items) - Smart TV's, Nvidia Shield, Ring Doorbell, Tablets, Phones, Pc's etc.
Dave
JamesGL
Sep 04, 2017NETGEAR Employee Retired
Hi RaymoC,
Can you try this firmware.
https://kb.netgear.com/000045842/R8000-Firmware-Version-1-0-3-54
RaymoC
Sep 06, 2017Aspirant
Hi James,
I updated the router to this version after I had posted here as I hadn't had any reply and I'm now back to the speeds on the original firmware but it's still nowhere near what I should be getting.
I am going to contact Amazon as Dave had mentioned he has had the same issues on his original router to see if another one works.
- whiteswanSep 06, 2017Guide
Hi
My replacement router is perfect.
One thing I didn't do is updat the firmware when I set it up.
The prompt is there - but I resisted - just in case it messed everything up.
I set it up as european region - everything on default settings out of the box - apart from a few ports I opened.
Dave
- RaymoCSep 10, 2017Aspirant
Thanks for the info Dave this is a great help to me.
I contacted Amazon and another one is being dispatched today to me so fingers crossed I finally get one that works.
Did you change the 5Ghz bands to the same SSID?
I'll let you know how it goes later when it comes!
Thanks again - much appreciated mate!
