RaymoC
Aug 18, 2017Aspirant
R8000 Slow WiFi download Speeds
Hi guys, I'm wondering if anyone can help me as I am on my second Nighthawk R8000 and I am getting nowhere near the download speeds I should be getting, any suggestions would be appreciated. I a...
- Sep 13, 2017
I am sorry an exchange did not work for you.
I did not use the "smart connect" feature - when I enabled this in the original router it seemed to slow my speeds down.
I settled on 2 seperate 5ghz wifi networks just as it comes out of the box.
Mine has been rock steady now since the exchange - I changed absolutely nothing at all out of the box - I only opened a port for a torrent file.
I am still amazed that I regularly get over 300 meg dload a floor above on a 300meg line - hardwired to the router it nudges 320 meg dload - just amazing.
The only thing I have noticed is that my NEST thermostat seems to disconnect from wifi every few days - it auto reconnects every single time so no big dramas - but I'm not too sure if it needs re-pairing to the new router or whether it's NEST servers.
Everything else connected to the router works flawlessly (around 25 different items) - Smart TV's, Nvidia Shield, Ring Doorbell, Tablets, Phones, Pc's etc.
Dave
whiteswan
Sep 13, 2017Guide
Dave
RaymoC
Sep 13, 2017Aspirant
It was worth a try mate, I guess I have been really unlucky with these. It's a shame because I really like the look of the router - if I could even have got close to the speeds I would have just kept it. It would have been a waste if I wanted to upgrade to the 300 package and not getting half of the speed.
Amazon have said they would exchange it as many times as it took to get a working one or to accept a refund so I have decided to take a refund and purchase another brand of router. I did think about trying another but if I've had three in a row that's never been right I wouldn't be confident I would get one that would be right (and then I would have to wait in all day for the replacement).
I'm glad you got a good one Dave and thanks again for your advice!
Kind Regards,
Raymond
