phantom48volts
Dec 20, 2020Initiate
R8000 Slow Wifi Speed - Firmware 1.0.4.66_10.1.75
Wifi speeds have dropped for all devices in my home. I'm not sure if the recent firmware update is the cause of this because we were seeing some slower speeds before. Current firmware version is1.0...
Kadaro
Dec 23, 2020Aspirant
Turn off QOS.
I noticed that after the speed test, it does not save the recent speed reported, and then trottles back using the older/much slower speed test results.
- JoeeeeeFeb 01, 2021AspirantI’m having the same issues with WiFi dropping and speeds decreasing! I download the old firmware update and it’s been running better! The firmware that I am using now is R7850-V1.0.5.48_10.0.4. I disabled the automatic update inside the interface of the router and would recommend doing some research after the next firmware is out.
- BrianwillsMay 26, 2021AspirantHow do you revert to a old firmware?
- DarrenMJun 02, 2021Sr. NETGEAR Moderator
you will need to do a manual install to revert.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
DarrenM
