phantom48volts
Dec 20, 2020Initiate
R8000 Slow Wifi Speed - Firmware 1.0.4.66_10.1.75
Wifi speeds have dropped for all devices in my home. I'm not sure if the recent firmware update is the cause of this because we were seeing some slower speeds before. Current firmware version is1.0...
Joeeeee
Feb 01, 2021Aspirant
I’m having the same issues with WiFi dropping and speeds decreasing! I download the old firmware update and it’s been running better! The firmware that I am using now is R7850-V1.0.5.48_10.0.4. I disabled the automatic update inside the interface of the router and would recommend doing some research after the next firmware is out.
Brianwills
May 26, 2021Aspirant
How do you revert to a old firmware?
- DarrenMJun 02, 2021Sr. NETGEAR Moderator
you will need to do a manual install to revert.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
DarrenM
