giacino
Aug 09, 2016Tutor
R8000 stuck at 100 mbps
Hi, I looked through the forums without findind a solution to my issue. Hence this post. I just upgrade my internet modem to 175mbps (from 100mbps) and got a new modem cisco dpc3848v. The mod...
- Aug 09, 2016
Do you have QoS enabled? If so, consider turning it off and rebooting. Or, more drastically, perform a factory reset followed by a minimal config (Wi-Fi and LAN settings).
Another option is to clone your MacMini's MAC address in the router's WAN settings.
giacino
Aug 09, 2016Tutor
Hi TheEther,
Thank you for your prompt reply unfortunately still not getting the expected speed.
R8000:
- Advanced Tab > Show Statistics: WAN, LAN1 & 2 are showing 1000M/Full.
- Lights are white
MacMini:
- Wired with Cat6.
- In Network Preferences > Advanced Settings > Hardware: Configure is set to automatically and the speed is 1000BastT (greyed out).
It might not be due to the MacMini because it got the speed when the Cisco dpc3848v moden was plugged directly into it. Futhermore my Macbook (802.11n) is getting the same 100 mbps (instead on 175 mbps).
What else should I try?
TheEther
Aug 09, 2016Guru
- giacinoAug 09, 2016Tutor
Turning off QOS did it.
I now have 175Mbps download speed.
Thank you very much for your help.
Gui
