Dilly79
Jun 26, 2022Tutor
R8000 time zone
Since reverting back to .68 firmware I am unable to change the time zone to uk. Anyone else have this problem?
Jun 26, 2022Guru - Experienced User
Is there a reason you downgraded?
did you try factory resetting after downgrading?
Dilly79
Jun 26, 2022Tutor
Yes I factory reset and was still the same. I’ve now installed.74 firmware and the time zone is ok now.
My parental controls (circle) don’t seem to work on the latest firmware + my download speeds were slow
- FURRYe38Jun 26, 2022Guru - Experienced User
Are you selecting the GMT for UK as seen here?
Noticed that if you have Traffic Meter or Circle enabled on the R8000, this seems to slow bandwidth down.
- Dilly79Jun 26, 2022TutorYes I did have traffic off. My circle is on
I selected GMT as in the picture
Now my next problem is my circle passcode. It’s not texting me the code, tried loads of times. I have premium- FURRYe38Jun 26, 2022Guru - Experienced User
Please post here for any Circle issues:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
There is some info at the top of that forum that may help.
