Cdiaz23
Nov 23, 2020Follower
R8000 tried updating and now it is down
I opened the app and saw there was a firmware update. I tried to update and now the whole router is down. I have no WiFi now and the power light is just blinking.
Nov 24, 2020Guru - Experienced User
if TFTP doesn't work, you can try using nmrpflash
michaelkenward
There are a few things to try before you get into tftp, which is not the easiest thing to do.
There is more severe, recovery reset, that you could try:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If it works, which is by no means guaranteed, you may be able to use the usual method to flash the firmware again.
Download the latest firmware for your device – or an older version if that is what you want – and read the Release Notes for how to install it.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
If that fails, you are into TFTP country.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This also explains how to tell Windows to use TFTP on your PC.
This isn't the easiest operation, so if you are forced to use it, you could try a web search to find videos that guide you through the process.
The good news is that TFTP has rescued many a dead device.
