Richard35
Jan 22, 2018Tutor
R8000 update and Samsung Smart TVs
I updated my R8000 to the newest firmware recently and I cannot get access to most of the streamed programs like Amazon Instants and Netflix on either of my Samsung smart TVs. Rolling back to firmwar...
- Feb 08, 2018
Hi Richard35,
Please try this firmware.
https://kb.netgear.com/000054461/R8000-Firmware-Version-1-0-4-12
JamesGL
Jan 28, 2018NETGEAR Employee Retired
Hi Richard35,
just to verify, both TVs are wired to the router.
Both cannot access streaming programs using the latest 2 firmwares?
Does other devices have internet access with the latest firmwares?
Richard35
Jan 29, 2018Tutor
Yes, both connected to router by wire, no wireless connection.
As far as I can tell everything else was working fine apart from the smart TVs access to streaming services. I’m now back on the older firmware that works so I’m not seeing any problems now.
Regards
Richard
- Richard35Jan 30, 2018Tutor
Just had email from this forum telling me there was a solution posted. No there isn’t! I’ve rolled back to the old FW to make things work but I was under the impression that there were security vulnerabilities in the old FW and that’s why I updated. What’s the story? Should I live with the older firmware and everything works or do I need to find a fix to make it work with the newer, (safer?) Firmware?
- JamesGLFeb 08, 2018NETGEAR Employee Retired
Hi Richard35,
- Richard35Feb 09, 2018Tutor
Hi James just installed and seems to be working OK. Many thanks, I'll have a proper play tomorrow and let ypu know if there's a problem. Very pleased thank you.
Richard
