Richard35
Jan 22, 2018Tutor
R8000 update and Samsung Smart TVs
I updated my R8000 to the newest firmware recently and I cannot get access to most of the streamed programs like Amazon Instants and Netflix on either of my Samsung smart TVs. Rolling back to firmwar...
- Feb 08, 2018
Hi Richard35,
Please try this firmware.
https://kb.netgear.com/000054461/R8000-Firmware-Version-1-0-4-12
Richard35
Jan 30, 2018Tutor
Just had email from this forum telling me there was a solution posted. No there isn’t! I’ve rolled back to the old FW to make things work but I was under the impression that there were security vulnerabilities in the old FW and that’s why I updated. What’s the story? Should I live with the older firmware and everything works or do I need to find a fix to make it work with the newer, (safer?) Firmware?
JamesGL
Feb 08, 2018NETGEAR Employee Retired
Hi Richard35,
- Richard35Feb 09, 2018Tutor
Hi James just installed and seems to be working OK. Many thanks, I'll have a proper play tomorrow and let ypu know if there's a problem. Very pleased thank you.
Richard
- JamesGLFeb 13, 2018NETGEAR Employee Retired
Hi Richard35,
Any updates on the firmware?
- Richard35Feb 14, 2018Tutor
Thanks James
All seems to be working OK. Certainly both TVs can access streaming services again now and everything else seems as before.
Many thanks for your help getting this fixed.
Richard
- JamesGLFeb 14, 2018NETGEAR Employee Retired
Hi Richard35,
You are welcome.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
