Anonymous
Jan 28, 2022R8000 Update stuck and will not boot back up after latest firmware upgrade.
I did a firmware upgrade last night and now the system can't connect. All the lights were on like it was working and nothing was working. After 2 hours I rebooted. Now the system just cycles. All...
- Jan 28, 2022
try the nmrpflash then
Anonymous
Jan 28, 2022The tftp isn't working because the R8000 is cycling. I tried running a ping in a separate cmd window so I could time the tftp as soon as I see it reply but it stops replying before the transfer finishes and I get a "Connect request failed"
Jan 28, 2022Guru - Experienced User
- AnonymousJan 28, 2022
I can't get nmrpflash to work on my Mac. I downloaded nmrpflash-master.zip extracted it and there is no nmrpflash in the directory to sudo run?
I I downloaded the NPcap and installed to get rid of the missing dll error. The nmrpflash -L only displays my eth and wifi mac addresses. The ping response isn't long enough for me to get the net# for the router?
- plemansJan 28, 2022Guru - Experienced User
You don't need a net# for the router. did you scroll down and read through how to use it?
