Anonymous
Jan 28, 2022R8000 Update stuck and will not boot back up after latest firmware upgrade.
I did a firmware upgrade last night and now the system can't connect. All the lights were on like it was working and nothing was working. After 2 hours I rebooted. Now the system just cycles. All...
- Jan 28, 2022
try the nmrpflash then
Jan 28, 2022Guru - Experienced User
Anonymous
Jan 28, 2022I I downloaded the NPcap and installed to get rid of the missing dll error. The nmrpflash -L only displays my eth and wifi mac addresses. The ping response isn't long enough for me to get the net# for the router?
- plemansJan 28, 2022Guru - Experienced User
You don't need a net# for the router. did you scroll down and read through how to use it?
- AnonymousJan 28, 2022
Sorry I miss understood. I followed the instructions and received an error "Timeout while waiting". I had the router off, started the nmrpflash and immediately turn it on when the waiting for connection appeared. Image file attached of error.
I tried a couple of more times and it finally took. Thanks for helping out with resolving this!!
