Cyrric
Jan 13, 2022Aspirant
R8000 Updated to 1.0.4.76_10.1.82
Today, I updated from 1.0.4.68_10.1.75 to 1.0.4.76_10.1.82 on my R8000 WiFi Router. After the update was complete, I noticed that my desktop PC, that is directly connected to my router through a netw...
Jan 13, 2022Guru - Experienced User
Did you factory reset the Router and setup from scratch after applying last version of FW?
If you look at this forum, you'll find various users posting with problems with recent FW. So you might keep FW loaded that works for you for now.
Cyrric
Thanks for the reply, FURRYe38!
I did not factory reset the router after upgrading the firmware. I had never had to do that before and to be honest, I pretty much use the router as is straight out of the box. It's in the middle of my workday at the moment, but this evening, I'll upgrade the firmware and factory reset to see if that solves the problems.
Thanks again!
- plemansJan 13, 2022Guru - Experienced User
Try enabling ipv6
- CyrricJan 13, 2022Aspirant
Thank you for the reply plemans. I will try enabling IPV6 when I do my testing. There seems to be several 'Internet Connection Types' to choose from on the IPv6 page. I'm assuming Auto Detect would suffice to use?
Thanks!
try the auto detect. after it setups up ipv6, then reboot the devices and router.
See if that helps.
