Cyrric
Jan 13, 2022Aspirant
R8000 Updated to 1.0.4.76_10.1.82
Today, I updated from 1.0.4.68_10.1.75 to 1.0.4.76_10.1.82 on my R8000 WiFi Router. After the update was complete, I noticed that my desktop PC, that is directly connected to my router through a netw...
Cyrric
Thank you for the reply plemans. I will try enabling IPV6 when I do my testing. There seems to be several 'Internet Connection Types' to choose from on the IPv6 page. I'm assuming Auto Detect would suffice to use?
Thanks!
Jan 13, 2022Guru - Experienced User
try the auto detect. after it setups up ipv6, then reboot the devices and router.
See if that helps.
