MoeShaker
Oct 26, 2018Aspirant
R8000-V1.0.4.18
After upgrading to R8000-V1.0.4.18 all machines at home connecting to 2.4 or 5GHz cannot open web pages. open safari or IE and pages just stopped with message "Cannot connect to Server". Press r...
- Oct 26, 2018
Please try to hard reset the router by using a pin or pencil tip to push in the indented reset slot in the back of the. Holding it for about 20 seconds then power off and on (few seconds) while still holding the reset button with the pen or pencil for another 20 seconds then release.
This will most likely return the router to factory default setting and then you can configure it again
Hope this will help.
PS. Newest fw for R8000 should be 1.0.4.18 and it works for me keeping the internet connection stable with DLNA OFF. (This is crutial)
Best
TerryPh
Oct 26, 2018Virtuoso
Best
MoeShaker
Nov 06, 2018Aspirant
It worked after a hard reset
Thank you all
Thank you all
